跳转到主内容
RCA Opal main board replacement
你所需要的
  1. RCA Opal main board replacement, Main Board: 步骤 1 中的图像 1,3 RCA Opal main board replacement, Main Board: 步骤 1 中的图像 2,3 RCA Opal main board replacement, Main Board: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • For this procedure, you will need tweezers, a prying tool, and a Phillips J000 screwdriver.
  2. RCA Opal main board replacement: 步骤 2 中的图像 1,2 RCA Opal main board replacement: 步骤 2 中的图像 2,2
    • The RCA Opal should have a blue front cover and a black back cover.
  3. RCA Opal main board replacement: 步骤 3 中的图像 1,2 RCA Opal main board replacement: 步骤 3 中的图像 2,2
    • Place the blade of the tweezers in between the blue and black surfaces.
    • Twist and pull the blue plastic cover from the black back surface. You may need to work around the edges of the blue plastic in order to pry it free. It should come off in one piece.
  4. RCA Opal main board replacement: 步骤 4 中的图像 1,1
    • The circular buttons should come off with the blue cover. If they do not, they can be removed with the prying tool.
  5. RCA Opal main board replacement: 步骤 5 中的图像 1,3 RCA Opal main board replacement: 步骤 5 中的图像 2,3 RCA Opal main board replacement: 步骤 5 中的图像 3,3
    • Using the prying tool, insert the tip of the tool in between the black plastic and the back cover of the device.
    • Pull upward to pry the black plastic away from the device. It will come off in pieces, but this is okay.
    • There will be thin black plastic surrounding four clear pieces where the buttons used to be located. Remove this as well.
  6. RCA Opal main board replacement: 步骤 6 中的图像 1,2 RCA Opal main board replacement: 步骤 6 中的图像 2,2
    • Now you should be able to see the main board. A small gold connector strip will connect the screen to the main board.
    • Locate a small white rectangular connector found at the top middle of the main board.
    • Using a prying tool or your fingernail, move the black plastic piece located at the bottom of the white connector to an upward position (toward the screen).
    • This should free the gold connector strip and allow you to remove the screen.
  7. RCA Opal main board replacement: 步骤 7 中的图像 1,1
    • Use the tweezers to pry off the black and silver plastic that lines the edges of the device.
  8. RCA Opal main board replacement: 步骤 8 中的图像 1,3 RCA Opal main board replacement: 步骤 8 中的图像 2,3 RCA Opal main board replacement: 步骤 8 中的图像 3,3
    • Lift up to remove the black plastic outline that fits within the back cover. This will be connected to the main board and battery.
  9. RCA Opal main board replacement: 步骤 9 中的图像 1,3 RCA Opal main board replacement: 步骤 9 中的图像 2,3 RCA Opal main board replacement: 步骤 9 中的图像 3,3
    • Locate four small screws on the four edges of the main board.
    • Using the Phillips +J000 screwdriver, remove these four screws.
    • This should disconnect the main board and battery from the remaining black plastic.
结论
Jane Beaufore
于09/24/15注册
219 声望
创作了2篇指南
团队
Ohio State, Team 1-1, Garvin Fall 2015 Ohio State, Team 1-1, Garvin Fall 2015 的会员
OSU-GARVIN-F15S1G1
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 707
