跳转到主内容
RCA Maven Pro 11 Volume Button Replacement
你所需要的
  1. RCA Maven Pro 11 Volume Button Replacement, Cover: 步骤 1 中的图像 1,2 RCA Maven Pro 11 Volume Button Replacement, Cover: 步骤 1 中的图像 2,2
    • Remove all the 8 mm Phillips head screws on the side and back of the device.
  2. RCA Maven Pro 11 Volume Button Replacement: 步骤 2 中的图像 1,2 RCA Maven Pro 11 Volume Button Replacement: 步骤 2 中的图像 2,2
    • Pry off the cover by sticking a wedge in between the screen and the cover.
    • Be careful with the plastic because it can easily break.
    • Once the cover is partly removed, use your hands to take off the rest of the cover.
  3. RCA Maven Pro 11 Volume Button Replacement, Volume Button: 步骤 3 中的图像 1,2 RCA Maven Pro 11 Volume Button Replacement, Volume Button: 步骤 3 中的图像 2,2
    • Locate the volume button on the inside of the cover.
    • Slide a wedge between the cover and the volume button and lightly lift it off.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 125
