跳转到主内容
RCA Maven Pro 11 Battery Replacement
你所需要的
  1. RCA Maven Pro 11 Battery Replacement, Cover: 步骤 1 中的图像 1,2 RCA Maven Pro 11 Battery Replacement, Cover: 步骤 1 中的图像 2,2
    • Remove all the 8 mm Phillips head screws on the side and back of the device.
  2. RCA Maven Pro 11 Battery Replacement: 步骤 2 中的图像 1,2 RCA Maven Pro 11 Battery Replacement: 步骤 2 中的图像 2,2
    • Pry off the cover by sticking a wedge in between the screen and the cover.
    • Be careful with the plastic because it can easily break.
    • Once the cover is partly removed, use your hands to take off the rest of the cover.
  3. RCA Maven Pro 11 Battery Replacement, Battery: 步骤 3 中的图像 1,2 RCA Maven Pro 11 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Pull out the pins circled in the picture.
    • These pins can be removed by hand. Just pull on them individually.
  4. RCA Maven Pro 11 Battery Replacement: 步骤 4 中的图像 1,1
    • Use the opening tools to peel the battery off of the panel.
    • The glue is located in the corners.
    • Do not bend or puncture the battery.
结论
另外一个人完成了本指南。
2条评论
My husband installed my new battery in my ex's haven pro tablet and when we turned it on it said battery charger 65%. I then turned it back off to co time charging to 100% it when I checked in a few hours, the battery level dropped to 20% and I cannot get it to recharge. It is now completely dead and will not take a charge what should I do?
Carol tyciak - 回复
My husband installed a new battery into my RCA Maven Pro tablet and when we turned it on, it showed 65% battery life. I then turned it off to continue to charge to 100%. When I checked it in about 4 hours, it was down to 20% and now it is depleted completely and I can't get it to recharge. What should I do now?
Carol tyciak - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 1,478
