当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
Remove the battery plate.
Place your finger at the bottom of the battery.
Lift up on the battery until it pops out from the LYRA X2400.
Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
Pull the silver case from the bottom of the device.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
