跳转到主内容
RCA Lyra X2400 flash card reader replacement
你所需要的
  1. RCA Lyra X2400 flash card reader replacement, Battery: 步骤 1 中的图像 1,3 RCA Lyra X2400 flash card reader replacement, Battery: 步骤 1 中的图像 2,3 RCA Lyra X2400 flash card reader replacement, Battery: 步骤 1 中的图像 3,3
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 flash card reader replacement, Screen: 步骤 2 中的图像 1,2 RCA Lyra X2400 flash card reader replacement, Screen: 步骤 2 中的图像 2,2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 flash card reader replacement: 步骤 3 中的图像 1,2 RCA Lyra X2400 flash card reader replacement: 步骤 3 中的图像 2,2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 flash card reader replacement: 步骤 4 中的图像 1,3 RCA Lyra X2400 flash card reader replacement: 步骤 4 中的图像 2,3 RCA Lyra X2400 flash card reader replacement: 步骤 4 中的图像 3,3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 flash card reader replacement, Motherboard: 步骤 5 中的图像 1,2 RCA Lyra X2400 flash card reader replacement, Motherboard: 步骤 5 中的图像 2,2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. RCA Lyra X2400 flash card reader replacement, Compact Flash Card: 步骤 6 中的图像 1,2 RCA Lyra X2400 flash card reader replacement, Compact Flash Card: 步骤 6 中的图像 2,2
    • Locate the compact flash card slot on the logic board. For assistance on locating this component look at the picture to the left.
    • Use soldering/desoldering tools to remove the compact flash card.
    • Replace compact flash card and use soldering tools to complete the replacement.
结论
Joseph Goodwin
于04/11/13注册
1 声望
创作了5篇指南
团队
Cal Poly, Team 17-3, Regan Spring 2013 Cal Poly, Team 17-3, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G3
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 226
