跳转到主内容
RCA CC310 Viewfinder Replacement
你所需要的
  1. RCA CC310 Viewfinder Replacement, Viewfinder: 步骤 1 中的图像 1,2 RCA CC310 Viewfinder Replacement, Viewfinder: 步骤 1 中的图像 2,2
    • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
    • Pushing the viewfinder assembly to the right makes lifting the flap easier.
    • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
  2. RCA CC310 Viewfinder Replacement: 步骤 2 中的图像 1,3 RCA CC310 Viewfinder Replacement: 步骤 2 中的图像 2,3 RCA CC310 Viewfinder Replacement: 步骤 2 中的图像 3,3
    • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable connects off of the viewfinder assembly.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Viewfinder Replacement: 步骤 3 中的图像 1,2 RCA CC310 Viewfinder Replacement: 步骤 3 中的图像 2,2
    • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up and remove.
  4. RCA CC310 Viewfinder Replacement: 步骤 4 中的图像 1,1
    • Flip back the viewfinder access tab.
    • Unscrew the 7.0mm ph #0 screw next to the mirror.
  5. RCA CC310 Viewfinder Replacement: 步骤 5 中的图像 1,3 RCA CC310 Viewfinder Replacement: 步骤 5 中的图像 2,3 RCA CC310 Viewfinder Replacement: 步骤 5 中的图像 3,3
    • Lift off both sides of the plastic assembly.
    • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
  6. RCA CC310 Viewfinder Replacement: 步骤 6 中的图像 1,2 RCA CC310 Viewfinder Replacement: 步骤 6 中的图像 2,2
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  7. RCA CC310 Viewfinder Replacement: 步骤 7 中的图像 1,3 RCA CC310 Viewfinder Replacement: 步骤 7 中的图像 2,3 RCA CC310 Viewfinder Replacement: 步骤 7 中的图像 3,3
    • Lift plastic housing and guide the wires from underneath.
    • Lift out the entire circuit board and viewfinder.
    • Replace entire circuit board and viewfinder assembly.
结论
Oliver Adams
于01/19/11注册
629 声望
创作了6篇指南
团队
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G20
4 名成员
创作了7篇指南
1指南评论
do you know where i can find a relacement one of these parts
Connor Byrley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,555
