本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will help you replace a faulty motherboard. To complete the repair, you will need to be able to solder intricate connections and keep track of many different plugs that will be disconnected during the removal process.
你所需要的
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Pull back the plastic tabs along the edges of the motherboard.
Disconnect all the cables along the left side of the motherboard.
另外一个人完成了本指南。
