本指南有最近更改,您可查看未经巡查的最新版本。
简介
If you have any problems due to a bad motherboard, this guide will instruct you how to replace it.
你所需要的
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Pull back the plastic tabs along the edges of the motherboard.
Disconnect all the cables along the left side of the motherboard.
另外一个人完成了本指南。
