跳转到主内容
RCA CC310 Main Motherboard Replacement
你所需要的
  1. RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: 步骤 1 中的图像 1,2 RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: 步骤 1 中的图像 2,2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Main Motherboard Replacement: 步骤 2 中的图像 1,2 RCA CC310 Main Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Main Motherboard Replacement: 步骤 3 中的图像 1,2 RCA CC310 Main Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Main Motherboard Replacement: 步骤 4 中的图像 1,2 RCA CC310 Main Motherboard Replacement: 步骤 4 中的图像 2,2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Main Motherboard Replacement, Main Motherboard: 步骤 5 中的图像 1,2 RCA CC310 Main Motherboard Replacement, Main Motherboard: 步骤 5 中的图像 2,2
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
  6. RCA CC310 Main Motherboard Replacement: 步骤 6 中的图像 1,2 RCA CC310 Main Motherboard Replacement: 步骤 6 中的图像 2,2
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
  7. RCA CC310 Main Motherboard Replacement: 步骤 7 中的图像 1,1
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
结论
另外一个人完成了本指南。
Oliver Adams
于01/19/11注册
629 声望
创作了6篇指南
团队
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G20
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 2,662
