简介
If you have any problems due to a bad motherboard, this guide will instruct you how to replace it.
Remove the 6-7.9mm ph#0 screws on the back and bottom.
Remove the one 3.8mm ph#0 screw on the bottom.
Remove the two 7.5mm ph#0 screws on the back and bottom.
Pull back the plastic tabs along the edges of the motherboard.
Disconnect all the cables along the left side of the motherboard.
即将完成!
结论
