当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Pull the left panel away from the rest of the camcorder.
Unplug the red speaker cable located at the rear of the device.
Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
Pull the plastic tabs away from the circuit board.
Pull the board away from the camcorder.
Use a spudger to help push the mini-circuit board away from the camcorder at the same time.
Unplug the cable in the middle of the effects board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
