跳转到主内容
RCA CC310 Effect Button Circuit Board Replacement
你所需要的
  1. RCA CC310 Effect Button Circuit Board Replacement, Disassembling RCA CC310 Left Cover: 步骤 1 中的图像 1,2 RCA CC310 Effect Button Circuit Board Replacement, Disassembling RCA CC310 Left Cover: 步骤 1 中的图像 2,2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Effect Button Circuit Board Replacement: 步骤 2 中的图像 1,2 RCA CC310 Effect Button Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Effect Button Circuit Board Replacement: 步骤 3 中的图像 1,2 RCA CC310 Effect Button Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Effect Button Circuit Board Replacement: 步骤 4 中的图像 1,2 RCA CC310 Effect Button Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Effect Button Circuit Board Replacement, Effect Button Circuit Board: 步骤 5 中的图像 1,2 RCA CC310 Effect Button Circuit Board Replacement, Effect Button Circuit Board: 步骤 5 中的图像 2,2
    • Unplug the two cables on the bottom of the effect button circuit board.
    • Unplug the cable at the top left side of the motherboard.
  6. RCA CC310 Effect Button Circuit Board Replacement: 步骤 6 中的图像 1,3 RCA CC310 Effect Button Circuit Board Replacement: 步骤 6 中的图像 2,3 RCA CC310 Effect Button Circuit Board Replacement: 步骤 6 中的图像 3,3
    • Pull the plastic tabs away from the circuit board.
    • Pull the board away from the camcorder.
    • Use a spudger to help push the mini-circuit board away from the camcorder at the same time.
    • Unplug the cable in the middle of the effects board.
结论
另外一个人完成了本指南。
Oliver Adams
于01/19/11注册
629 声望
创作了6篇指南
团队
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G20
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,880
