跳转到主内容
RCA 8 Apollo Volume Button Replacement
你所需要的
  1. RCA 8 Apollo Volume Button Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Volume Button Replacement: 步骤 2 中的图像 1,2 RCA 8 Apollo Volume Button Replacement: 步骤 2 中的图像 2,2
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Volume Button Replacement: 步骤 3 中的图像 1,2 RCA 8 Apollo Volume Button Replacement: 步骤 3 中的图像 2,2
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
  4. RCA 8 Apollo Volume Button Replacement, Volume Button: 步骤 4 中的图像 1,1
    • The volume button control pad is located in the back panel, on the right side of the tablet.
    • Push on the outside of the volume button control pad and it will simply loosen and detach.
结论
Brooke Still
于04/12/24注册
123 声望
撰写一个指南
团队
Casper College, Team 1-1, Lareau Spring 2024 Casper College, Team 1-1, Lareau Spring 2024 的会员
CASC-LAREAU-S24S1G1
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 78
