跳转到主内容
RCA 22” DECK215R HDTV Screen Replacement
你所需要的
  1. RCA 22” DECK215R HDTV Screen Replacement, Removing the Stand: 步骤 1 中的图像 1,2 RCA 22” DECK215R HDTV Screen Replacement, Removing the Stand: 步骤 1 中的图像 2,2
    • Before disassembling your television, ensure that all cables are unplugged from their power source to avoid serious injury or death from electrocution.
    • Lay the TV flat with the screen facing down.
    • Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
    • Remove the stand by lifting it away from the TV's backing.
  2. RCA 22” DECK215R HDTV Screen Replacement, Removing the Back Panel: 步骤 2 中的图像 1,2 RCA 22” DECK215R HDTV Screen Replacement, Removing the Back Panel: 步骤 2 中的图像 2,2
    • Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
    • Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
    • While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
  3. RCA 22” DECK215R HDTV Screen Replacement, Locate Pin: 步骤 3 中的图像 1,1
    • Position the television to where the back panel is resting on the table and the screen is vertical.
    • Peel the tape covering the ribbon cable horizontally.
  4. RCA 22” DECK215R HDTV Screen Replacement: 步骤 4 中的图像 1,3 RCA 22” DECK215R HDTV Screen Replacement: 步骤 4 中的图像 2,3 RCA 22” DECK215R HDTV Screen Replacement: 步骤 4 中的图像 3,3
    • Pinch the clamps on both sides of the ribbon cable casing to detach it from the screen panel.
    • Remove the screen to isolate the back panel.
  5. RCA 22” DECK215R HDTV Screen Replacement, Remove Screws: 步骤 5 中的图像 1,1
    • Remove the four, 12mm Phillips #2 screws from the outer edge of the back of the screen panel.
  6. RCA 22” DECK215R HDTV Screen Replacement, Remove the Screen from the Frame: 步骤 6 中的图像 1,1
    • Lift up the screen to remove it from the plastic frame.
  7. RCA 22” DECK215R HDTV Screen Replacement, Remove Brackets from the Side of the Screen: 步骤 7 中的图像 1,1
    • Remove the two, 5mm Phillips #2 screws from the metal bracket attached to the horizontal side of the TV and take the bracket off.
    • Repeat this process on the other side of the TV to completely isolate the screen.
结论
2等其他人完成本指南。
Patrick Soper
于01/15/15注册
691 声望
创作了6篇指南
团队
Cal Poly, Team 70-2, Forte Winter 2015 Cal Poly, Team 70-2, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 1,350
