跳转到主内容
RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement
你所需要的
  1. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: 步骤 1 中的图像 1,3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: 步骤 1 中的图像 2,3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: 步骤 1 中的图像 3,3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 2 中的图像 1,2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 4 中的图像 1,2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Battery: 步骤 5 中的图像 1,1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 8 中的图像 1,2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 9 中的图像 1,2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
  10. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Antenna: 步骤 10 中的图像 1,1
    • Identify the grey wire on the right side of the device.
  11. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the orange ribbon cable over the wire.
  12. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the antenna using a soldering iron.
  13. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Motherboard: 步骤 13 中的图像 1,1
    • Remove the blue and black wire from the top of the motherboard.
  14. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the screws from the motherboard.
  15. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the motherboard.
结论
Marcus Elysee
于10/25/19注册
97 声望
撰写一个指南
团队
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G8
3 名成员
创作了4篇指南
一条评论
Where can I buy this motherboard?
waymond everett - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 34
总计 1,340
