跳转到主内容
RCA 10 Viking Pro RCT6K03W13 Battery Replacement
你所需要的
  1. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: 步骤 1 中的图像 1,3 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: 步骤 1 中的图像 2,3 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: 步骤 1 中的图像 3,3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 2 中的图像 1,2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 3 中的图像 1,1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 4 中的图像 1,2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 4 中的图像 2,2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 6 中的图像 1,1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 7 中的图像 1,1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 8 中的图像 1,2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 8 中的图像 2,2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 9 中的图像 1,2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 步骤 9 中的图像 2,2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
结论
5等其他人完成本指南。
Ryan Wickett
于10/25/19注册
632 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G8
3 名成员
创作了4篇指南
4条评论
Where can I get the battery for this?
Justin - 回复
You can get a battery from Amazon or Walmart.com your wellcome ?
GLENDA Vandergrift -
How much voltage should the battery put out in order for the tablet to turn on?
Jesus Rios - 回复
How much
How much
jennylyne_08 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 49
总计 3,050
