跳转到主内容
RC Vehicle Electronic Speed Control Replacement
你所需要的
  1. RC Vehicle Electronic Speed Control Replacement, Electronic Speed Control: 步骤 1 中的图像 1,2 RC Vehicle Electronic Speed Control Replacement, Electronic Speed Control: 步骤 1 中的图像 2,2
    • Position the car so that the wires are facing upwards.
  2. RC Vehicle Electronic Speed Control Replacement: 步骤 2 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 2 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 2 中的图像 3,3
    • Unplug the blue wire.
    • Unplug the yellow wire.
    • To unplug these wires, firmly grasp the metal connector, then pull straight out.
    • Grab the wires by their metal connector, not the wire itself, to prevent any damage to the wires.
  3. RC Vehicle Electronic Speed Control Replacement: 步骤 3 中的图像 1,2 RC Vehicle Electronic Speed Control Replacement: 步骤 3 中的图像 2,2
    • Unplug the thin bundle of black, white, and red wires.
    • Move both ends to the side of the car to clear your workspace.
  4. RC Vehicle Electronic Speed Control Replacement: 步骤 4 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 4 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    • Slide an opening tool beneath the red controller unit.
    • Pry upwards with moderate force until the controller unit is detached.
  5. RC Vehicle Electronic Speed Control Replacement: 步骤 5 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 5 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    • Slide an opening tool beneath the power button.
    • Pry upwards with moderate force until the power button is detached.
  6. RC Vehicle Electronic Speed Control Replacement: 步骤 6 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 6 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 6 中的图像 3,3
    • Dampen a shop towel with 99.9% pure isopropyl alcohol.
    • Rub the dampened towel over any residual adhesive on the car.
    • Clean the residue until the surface is smooth.
    • Isopropyl alcohol is extremely flammable. Work away from heat sources to prevent serious fires.
  7. RC Vehicle Electronic Speed Control Replacement: 步骤 7 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 7 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 7 中的图像 3,3
    • From this step onwards, work with your new controller unit, not the old one.
    • Rub the dampened towel over the bottom of the controller unit.
  8. RC Vehicle Electronic Speed Control Replacement: 步骤 8 中的图像 1,1
  9. RC Vehicle Electronic Speed Control Replacement: 步骤 9 中的图像 1,2 RC Vehicle Electronic Speed Control Replacement: 步骤 9 中的图像 2,2
    • Position the controller unit so that the bottom faces upwards.
    • Unwind 1 inch of double-sided adhesive.
    • Center the adhesive on the bottom and press down to secure it.
  10. RC Vehicle Electronic Speed Control Replacement: 步骤 10 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 10 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    Utility Scissors
    $5.59
    • Trim any excess adhesive from the bottom of the controller unit.
    • Smooth the adhesive by rubbing it with your thumb.
  11. RC Vehicle Electronic Speed Control Replacement: 步骤 11 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 11 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 11 中的图像 3,3
    • Repeat Steps 9 and 10 with the power button instead of the controller unit.
  12. RC Vehicle Electronic Speed Control Replacement: 步骤 12 中的图像 1,1
    • The bottom of your controller unit and power button should look like the given image.
  13. RC Vehicle Electronic Speed Control Replacement: 步骤 13 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 13 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 13 中的图像 3,3
    • Peel off the red layer from the adhesive attached to the controller unit.
    • Secure it to the original spot of the old controller unit.
    • Use a precision knife to easily remove the layer on your double-sided adhesive.
  14. RC Vehicle Electronic Speed Control Replacement: 步骤 14 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 14 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 14 中的图像 3,3
    • Peel off the red layer from the double-sided adhesive attached to the power button.
    • Secure it to the original spot of the old power button.
  15. RC Vehicle Electronic Speed Control Replacement: 步骤 15 中的图像 1,2 RC Vehicle Electronic Speed Control Replacement: 步骤 15 中的图像 2,2
    • Locate the thin bundle of black, white, and red wires and reconnect their heads.
  16. RC Vehicle Electronic Speed Control Replacement: 步骤 16 中的图像 1,2 RC Vehicle Electronic Speed Control Replacement: 步骤 16 中的图像 2,2
    • Secure the black, white, and red wires to the frame of your car using two 4-inch zip ties.
  17. RC Vehicle Electronic Speed Control Replacement: 步骤 17 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 17 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 17 中的图像 3,3
    • Plug the yellow wire into the connector at the bottom of the motor (Image 2).
    • Plug the blue wire into the connector at the top of the motor (Image 3).
  18. RC Vehicle Electronic Speed Control Replacement: 步骤 18 中的图像 1,3 RC Vehicle Electronic Speed Control Replacement: 步骤 18 中的图像 2,3 RC Vehicle Electronic Speed Control Replacement: 步骤 18 中的图像 3,3
    • Tuck away the thick red and black charging wires.
    • Securing the charging wires using Velcro is optional but recommended to keep the wires from moving while driving your vehicle.
终点
Maxwell Limon
于11/11/22注册
277 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 56
总计 1,087
