跳转到主内容
RAVPower FileHub Travel Router AC750 Disassembly
你所需要的
  1. RAVPower FileHub Travel Router AC750 Disassembly, Bring your device and make sure everything is off and disconnected: 步骤 1 中的图像 1,2 RAVPower FileHub Travel Router AC750 Disassembly, Bring your device and make sure everything is off and disconnected: 步骤 1 中的图像 2,2
    • Brand New RAVPower FileHub Travel Router AC750
    • No screws what so ever, all is tightly sealed.
  2. RAVPower FileHub Travel Router AC750 Disassembly, Open the rubber seal and shimmy on the case surrounding the connectors: 步骤 2 中的图像 1,3 RAVPower FileHub Travel Router AC750 Disassembly, Open the rubber seal and shimmy on the case surrounding the connectors: 步骤 2 中的图像 2,3 RAVPower FileHub Travel Router AC750 Disassembly, Open the rubber seal and shimmy on the case surrounding the connectors: 步骤 2 中的图像 3,3
    • Open the rubber seal and begin, very carefully, opening the surroundings.
    • 'Note that there is an adhesive on the other side holding the case' among other elements like: battery (most prominent), the WiFi antennas (is the 2.4Ghz & 5Ghz on the top of the case) and the lights circuit of the device.
  3. RAVPower FileHub Travel Router AC750 Disassembly, Pull the case a bit, be careful not to break the top parts: 步骤 3 中的图像 1,3 RAVPower FileHub Travel Router AC750 Disassembly, Pull the case a bit, be careful not to break the top parts: 步骤 3 中的图像 2,3 RAVPower FileHub Travel Router AC750 Disassembly, Pull the case a bit, be careful not to break the top parts: 步骤 3 中的图像 3,3
    • Again, open carefully because of the attached items to the top case. In this picture a accidentally broke the connection in the 5Ghz WiFi Antenna.
  4. RAVPower FileHub Travel Router AC750 Disassembly, It's open! congrats!: 步骤 4 中的图像 1,3 RAVPower FileHub Travel Router AC750 Disassembly, It's open! congrats!: 步骤 4 中的图像 2,3 RAVPower FileHub Travel Router AC750 Disassembly, It's open! congrats!: 步骤 4 中的图像 3,3
    • Insert wisdom here.
结论
Andres Urena
于12/01/20注册
139 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 1,242
