跳转到主内容
Quiksilver The Fifty50 Back Panel Replacement
你所需要的
  1. Quiksilver The Fifty50 Back Panel Replacement, Strap: 步骤 1 中的图像 1,2 Quiksilver The Fifty50 Back Panel Replacement, Strap: 步骤 1 中的图像 2,2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Back Panel Replacement: 步骤 2 中的图像 1,2 Quiksilver The Fifty50 Back Panel Replacement: 步骤 2 中的图像 2,2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Back Panel Replacement, Back Panel: 步骤 3 中的图像 1,2 Quiksilver The Fifty50 Back Panel Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Back Panel Replacement: 步骤 4 中的图像 1,1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
结论
Sue Giske
于07/16/19注册
622 声望
创作了5篇指南
团队
UW Tacoma, Team S1-G4, Liner Summer 2019 UW Tacoma, Team S1-G4, Liner Summer 2019 的会员
UWT-LINER-SU19S1G4
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 198
