跳转到主内容
Quick way to test LEDs
  1. Quick way to test LEDs, Quick way to test an LED: 步骤 1 中的图像 1,3 Quick way to test LEDs, Quick way to test an LED: 步骤 1 中的图像 2,3 Quick way to test LEDs, Quick way to test an LED: 步骤 1 中的图像 3,3
    • In most Christmas light strands that I have seen, the LEDs are inserted into a plug and the plug goes into a socket on the strand. If one (or more)LEDs is bad, an entire section of the strand will not light up.
    • Previously I have suggested finding a known good LED from a section that works, and using it to replace each LED in the bad section, one by one, to see if it lights up, thus identifying the bad one. This only works if one and only one LED is bad, however. And it's tedious.
  2. Quick way to test LEDs, Easier method: 步骤 3 中的图像 1,3 Quick way to test LEDs, Easier method: 步骤 3 中的图像 2,3 Quick way to test LEDs, Easier method: 步骤 3 中的图像 3,3
    • An easier way: press one side of a coin battery to one of the LED leads (still in the plug), and then use a pair of metal pliers to simultaneously touch the other lead to the OTHER side of the battery. The piers act as a conductor to complete the circuit. If it doesn't work, also try turning the battery over- LEDs only conduct in one direction.
    • Any 3V coin battery will do. If the LED doesn't light up with the battery in either direction, then it is bad- replace it.
  3. Quick way to test LEDs, Great way to test LED Christmas Lights: 步骤 5 中的图像 1,1
    • The pliers were too difficult for me so I taped wires to the button battery and use a clothespin to hold the bulb.
结论
2等其他人完成本指南。
Betty Lise
于02/03/13注册
752 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 56
过去 30 天: 210
总计 1,313
