跳转到主内容
加入维修社区 - 创建账户
Quick Antenna Connection Check for Delphi MyFi XM2GO
你所需要的
  1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: 步骤 1 中的图像 1,3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: 步骤 1 中的图像 2,3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: 步骤 1 中的图像 3,3
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
    询问修复机器人
    添加评论
  2. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: 步骤 2 中的图像 1,3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: 步骤 2 中的图像 2,3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: 步骤 2 中的图像 3,3
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
    添加评论
  3. Quick Antenna Connection Check for Delphi MyFi XM2GO, Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 3 中的图像 1,1
    • Under the battery is a magnetic mat, shown in red, that shields battery interference with the reception of the XM Satellite antenna.
    • This mat is stuck to the back of the device like a sticker and can be removed.
    • CAUTION: Do not operate the device without this magnetic shield.
    询问修复机器人
    添加评论
  4. Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 4 中的图像 1,3 Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 4 中的图像 2,3 Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 4 中的图像 3,3
    • On the bottom left side of the magnetic mat, the corner can be lifted up to reveal the U.FL antenna connector. A spudger or your fingernails can be used to pry up the corners.
    • These U.FL antenna connections are standard for most portable devices and WiFi cards. They may become detached through use and may be checked if no reception is present.
    • Lift up the corner and notice the two connectors going to the PCB.
    询问修复机器人
    添加评论
  5. Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 5 中的图像 1,2 Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 5 中的图像 2,2
    • Both of these connectors must be firmly attached to the PCB. Try pressing them firmly to make sure they are making full contact.
    询问修复机器人
    添加评论
  6. Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 6 中的图像 1,3 Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 6 中的图像 2,3 Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 6 中的图像 3,3
    • On the top right corner, the magnetic mat can be lifted up to check another U.FL connector as with the 3rd step.
    • This mat can be pressed down again to secure after checking the connector.
    询问修复机器人
    添加评论
  7. Quick Antenna Connection Check for Delphi MyFi XM2GO: 步骤 7 中的图像 1,1
    • Try pressing down on the U.FL connector, as seen in this picture, to ensure a secure connection.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Scott Byer
于03/09/12注册
88 声望
创作了5篇指南
团队
Clemson, Team 1-2, Benson Spring 2012 Clemson, Team 1-2, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G2
3 名成员
创作了18篇指南
1指南评论
la radio sigue sin funcionar
luis - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 39
总计 3,447
