跳转到主内容
Quasar Microwave Capacitor Replacement
你所需要的
  1. Quasar Microwave Capacitor Replacement, Disassembling Quasar Microwave Outer Cover: 步骤 1 中的图像 1,1
    • Disconnect the power supply cord from the outlet.
  2. Quasar Microwave Capacitor Replacement: 步骤 2 中的图像 1,2 Quasar Microwave Capacitor Replacement: 步骤 2 中的图像 2,2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Quasar Microwave Capacitor Replacement: 步骤 3 中的图像 1,2 Quasar Microwave Capacitor Replacement: 步骤 3 中的图像 2,2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Quasar Microwave Capacitor Replacement: 步骤 4 中的图像 1,3 Quasar Microwave Capacitor Replacement: 步骤 4 中的图像 2,3 Quasar Microwave Capacitor Replacement: 步骤 4 中的图像 3,3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Quasar Microwave Capacitor Replacement, Capacitor: 步骤 5 中的图像 1,2 Quasar Microwave Capacitor Replacement, Capacitor: 步骤 5 中的图像 2,2
    • Old electronics collect dust, no matter if they are in active use or being stored. It is recommended to clear out some of the dust prior to affecting any complicated repairs. Use compressed air, and wear a dust mask and goggles. Always use precaution when working with old electronics.
    • The capacitor stores a small amount of electrical energy. Discharge capacitor by placing a screw driver across the terminals. Use a screwdriver with a non-metallic handle and a shaft that is longer than 4” (10.75mm) Touch the metal shaft of the screwdriver simultaneously to both metal terminals of the capacitor. There should be a spark.
    • If the capacitor sparks, you can stop reading here. The spark indicates that the capacitor is working properly. If the capacitor does not spark, read on to Step 6.
  6. Quasar Microwave Capacitor Replacement: 步骤 6 中的图像 1,1
    • Place the multimeter on resistance mode and test the resistance of the capacitor.
    • If the resistance increases/decreases, the capacitor is working fine. If the resistance of the capacitor reads 0 or over several kilo ohms, the capacitor needs to be replaced.
  7. Quasar Microwave Capacitor Replacement: 步骤 7 中的图像 1,3 Quasar Microwave Capacitor Replacement: 步骤 7 中的图像 2,3 Quasar Microwave Capacitor Replacement: 步骤 7 中的图像 3,3
    • Tip the microwave back so it is lying face up. This allows access to the screws beneath the transformer.
  8. Quasar Microwave Capacitor Replacement: 步骤 8 中的图像 1,2 Quasar Microwave Capacitor Replacement: 步骤 8 中的图像 2,2
    • Locate the transformer. The capacitor cannot be removed without removing the transformer first.
    • Locate and unhook all wires connecting the transformer to the rest of the microwave.
    • Take note of where each wire connects before disconnecting. Wiring a microwave incorrectly can cause serious damage.
  9. Quasar Microwave Capacitor Replacement: 步骤 9 中的图像 1,1
    • Remove the four exterior screws securing the transformer to the microwave frame.
  10. Quasar Microwave Capacitor Replacement: 步骤 10 中的图像 1,3 Quasar Microwave Capacitor Replacement: 步骤 10 中的图像 2,3 Quasar Microwave Capacitor Replacement: 步骤 10 中的图像 3,3
    • Remove the transformer.
  11. Quasar Microwave Capacitor Replacement: 步骤 11 中的图像 1,2 Quasar Microwave Capacitor Replacement: 步骤 11 中的图像 2,2
    • The metal band locking the capacitor in place can now be accessed. Locate and remove the screw securing the the metal band.
    • Lift the metal band off the capacitor.
  12. Quasar Microwave Capacitor Replacement: 步骤 12 中的图像 1,3 Quasar Microwave Capacitor Replacement: 步骤 12 中的图像 2,3 Quasar Microwave Capacitor Replacement: 步骤 12 中的图像 3,3
    • Remove the capacitor.
  13. Quasar Microwave Capacitor Replacement: 步骤 13 中的图像 1,1
    • You can now install a replacement capacitor.
    • Repeat all steps in reverse order to install a capacitor in a Quasar Microwave MQ7774XW (1984).
结论
另外一个人完成了本指南。
Michael
于09/26/12注册
237 声望
创作了2篇指南
团队
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G12
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 43
总计 6,981
