跳转到主内容
Quantum View 10.1 camera Replacement
你所需要的
  1. Quantum View 10.1 camera Replacement, Open Quantum View case: 步骤 1 中的图像 1,1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: 步骤 2 中的图像 1,2 Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: 步骤 2 中的图像 2,2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 camera Replacement, Unhooking the battery: 步骤 3 中的图像 1,2 Quantum View 10.1 camera Replacement, Unhooking the battery: 步骤 3 中的图像 2,2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
    • Remove yellow plastic and carefully pull clip away from connection.
  4. Quantum View 10.1 camera Replacement, Remove camera clip: 步骤 5 中的图像 1,2 Quantum View 10.1 camera Replacement, Remove camera clip: 步骤 5 中的图像 2,2
    • Remove yellow tape.
    • Unclip ribbon connector.
  5. Quantum View 10.1 camera Replacement, Remove camera: 步骤 6 中的图像 1,2 Quantum View 10.1 camera Replacement, Remove camera: 步骤 6 中的图像 2,2
    • Unscrew plastic camera holder using a PH00 screwdriver bit.
    • Release the plastic holder tab and remove camera.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 276
