跳转到主内容
加入维修社区 - 创建账户
Quantum View 10.1 Volume buttons Replacement
你所需要的
  1. Quantum View 10.1 Volume buttons  Replacement, Open Quantum View case: 步骤 1 中的图像 1,1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Volume buttons  Replacement, Removing the electrical tape and magnets.: 步骤 2 中的图像 1,2 Quantum View 10.1 Volume buttons  Replacement, Removing the electrical tape and magnets.: 步骤 2 中的图像 2,2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Volume buttons  Replacement, Unhooking the battery: 步骤 3 中的图像 1,2 Quantum View 10.1 Volume buttons  Replacement, Unhooking the battery: 步骤 3 中的图像 2,2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
  4. Quantum View 10.1 Volume buttons  Replacement, Disconnecting the buttons: 步骤 4 中的图像 1,1
    • Peel back the yellow clear tape. Followed by the use of a plastic opening tool to release the ribbon connection.
  5. Quantum View 10.1 Volume buttons  Replacement, Removing the volume buttons: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers genitally pull up on the volume button board to remove.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 324
