跳转到主内容
Quantum View 10.1 Motherboard Replacement
你所需要的
  1. Quantum View 10.1 Motherboard Replacement, Open Quantum View case: 步骤 1 中的图像 1,1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Motherboard Replacement, Removing the electrical tape and magnets.: 步骤 2 中的图像 1,2 Quantum View 10.1 Motherboard Replacement, Removing the electrical tape and magnets.: 步骤 2 中的图像 2,2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Motherboard Replacement, Unhooking the battery: 步骤 3 中的图像 1,2 Quantum View 10.1 Motherboard Replacement, Unhooking the battery: 步骤 3 中的图像 2,2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
  4. Quantum View 10.1 Motherboard Replacement, Disconnect Cables: 步骤 4 中的图像 1,3 Quantum View 10.1 Motherboard Replacement, Disconnect Cables: 步骤 4 中的图像 2,3 Quantum View 10.1 Motherboard Replacement, Disconnect Cables: 步骤 4 中的图像 3,3
    • Remove silver protective sticker and set to the side.
    • Ensure all ribbon cables and other connectors are disconnected from mother board.
  5. Quantum View 10.1 Motherboard Replacement, Remove Screws: 步骤 5 中的图像 1,2 Quantum View 10.1 Motherboard Replacement, Remove Screws: 步骤 5 中的图像 2,2
    • There are 4 small screws connecting the motherboard to the frame of the device. Take a PH00 bit screw driver to remove these screws.
  6. Quantum View 10.1 Motherboard Replacement, Remove Motherboard: 步骤 6 中的图像 1,1
    • Gently and carefully lift motherboard straight up from frame.
结论
另外一个人完成了本指南。
4条评论
tell me which battery is suitable ?
Иван Шульга - 回复
Hi
I would like to request for my tablet bios.bin EM_i8211 V6.1 (this code on board )
My tablet is fail bios
Please help me,
Ye Yint Aung - 回复
Hi
My tablet bois missing when it was updating …
MB model is EM_i8211 V6.1
Please help me for find bios file …
tnx alot …
p30emaile@yahoo.com
Nima khalaji - 回复
Hello, I have a CSL Panhter Tab 10 v2 which has the same mainboard. Because my bios is defective, it won't start anymore! My request, could you read the BIOS and attach the ROM.bin to a PM or send me a link. there is simply nothing left to find I would be very grateful
Felix Klein - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 23
总计 1,237
