跳转到主内容
Quantum View 10.1 Keyboard connector solid state board Replacement
你所需要的
  1. Quantum View 10.1 Keyboard connector solid state board Replacement, Open Quantum View case: 步骤 1 中的图像 1,1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the electrical tape and magnets.: 步骤 2 中的图像 1,2 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the electrical tape and magnets.: 步骤 2 中的图像 2,2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Keyboard connector solid state board Replacement, Unhooking the battery: 步骤 3 中的图像 1,2 Quantum View 10.1 Keyboard connector solid state board Replacement, Unhooking the battery: 步骤 3 中的图像 2,2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
  4. Quantum View 10.1 Keyboard connector solid state board Replacement, Removing cover plate: 步骤 4 中的图像 1,3 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing cover plate: 步骤 4 中的图像 2,3 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing cover plate: 步骤 4 中的图像 3,3
    • Using a PH00 Philips screwdriver bit remove 5 screws from the cover on top of the keyboard solid state board.
    • Then place cover off to the side.
  5. Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the keyboard  solid state board: 步骤 5 中的图像 1,3 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the keyboard  solid state board: 步骤 5 中的图像 2,3 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the keyboard  solid state board: 步骤 5 中的图像 3,3
    • Using a PH000 Philips screw driver bit remove the two screws on securing the board to the case.
    • Then using a plastic opening tool slowly and carefully wedge the tool between the cable ribbon and the black connector portion. Then carefully rock the tool up and down to lift the connector hinge.
    • The board can now be removed.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 229
