跳转到主内容
Quantum Axis A23 Speaker Replacement
你所需要的
  1. Quantum Axis A23 Speaker Replacement, Removing the Case: 步骤 1 中的图像 1,1
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
  2. Quantum Axis A23 Speaker Replacement, Cutting the Speaker Wiring: 步骤 2 中的图像 1,1
    • Once the device is open, take the speaker’s wiring and cut both the red and black wires in the middle using the wire cutter/stripper tool. Then strip both the red and black wires with the same tool.
    • Be careful when stripping wires as they are delicate and likely to break apart.
  3. Quantum Axis A23 Speaker Replacement: 步骤 3 中的图像 1,1
    • Take the new speaker and strip both the red and black wires in the middle with wire stripper/cutter tool.
  4. Quantum Axis A23 Speaker Replacement: 步骤 4 中的图像 1,1
    • Take the red wire from the speaker and the red wire from your device and twist the two ends together then wrap in electrical tape. Repeat this step for the black wires.
结论
Place the speaker back in position and snap rear case in place to complete the repair.
Nicole
于01/12/15注册
407 声望
创作了4篇指南
团队
USF Tampa, Team 1-5, Tanski Winter 2015 USF Tampa, Team 1-5, Tanski Winter 2015 的会员
USFT-TANSKI-W15S1G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 170
