跳转到主内容
Quantum Axis A23 Motherboard Replacement
你所需要的
  1. Quantum Axis A23 Motherboard  Replacement, Removing the Case: 步骤 1 中的图像 1,1
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
  2. Quantum Axis A23 Motherboard  Replacement, Unscrewing the Motherboard: 步骤 2 中的图像 1,1
    • Remove all three screws holding down the motherboard, using the Phillips #00 Precision Screwdriver and slot in the Phillips Head PH #0.
  3. Quantum Axis A23 Motherboard  Replacement: 步骤 3 中的图像 1,1
    • Using the small needle nose pliers, carefully remove the small yellow ribbons that are attached to the motherboard.
  4. Quantum Axis A23 Motherboard  Replacement: 步骤 4 中的图像 1,2 Quantum Axis A23 Motherboard  Replacement: 步骤 4 中的图像 2,2
    • Cut the red and black wires that connect the battery, screen, camera, and speakers to the motherboard.
  5. Quantum Axis A23 Motherboard  Replacement, Screwing the Motherboard Back On: 步骤 5 中的图像 1,2 Quantum Axis A23 Motherboard  Replacement, Screwing the Motherboard Back On: 步骤 5 中的图像 2,2
    • Take the the new motherboard and screw it in with the screws used on the previous motherboard, starting with the top right and bottom left corners.
    • Screw on the top left corner last
  6. Quantum Axis A23 Motherboard  Replacement: 步骤 6 中的图像 1,1
    • Strip both the red and black wires in the middle with a wire stripper/cutter tool. Do this for all wires that were cut, as well as for the wires on your new motherboard.
  7. Quantum Axis A23 Motherboard  Replacement: 步骤 7 中的图像 1,1
    • Take the red wire from the specified part and attach to the red wire on the motherboard, then twist the two ends together and wrap in electrical tape. Repeat this step for the black wires.
    • Do this for every part that was attached to the motherboard.
结论
Snap the rear case back on to finish this repair.
Nicole
于01/12/15注册
407 声望
创作了4篇指南
团队
USF Tampa, Team 1-5, Tanski Winter 2015 USF Tampa, Team 1-5, Tanski Winter 2015 的会员
USFT-TANSKI-W15S1G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 473
