跳转到主内容
Quantum Axis A23 Camera Replacement
你所需要的
  1. Quantum Axis A23 Camera Replacement, Removing the Case: 步骤 1 中的图像 1,1
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
  2. Quantum Axis A23 Camera Replacement, Detaching the Camera from the Motherboard: 步骤 2 中的图像 1,1
    • Use small needle nose pliers to carefully remove the yellow ribbon attached to the motherboard.
  3. Quantum Axis A23 Camera Replacement, Detaching the Camera from the Back of the Screen: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove the black tape holding the camera down.
  4. Quantum Axis A23 Camera Replacement, Attaching New Ribbon to Motherboard Slot: 步骤 4 中的图像 1,1
    • Slot the new dual camera ribbon into the motherboard.
  5. Quantum Axis A23 Camera Replacement, Attach New Dual Cameras to Screen: 步骤 5 中的图像 1,1
    • Attach dual cameras to the back of the screen with the black tape. Align the cameras with the designated hole in the case.
    • Fold over the camera piece so the camera are on top of each other with lenses facing out and the top as the rear.
结论
Snap the rear case back on (carefully aligning the back camera with the camera hole on the case) to finish this repair.
Randy Janz
于01/15/15注册
101 声望
撰写一个指南
团队
USF Tampa, Team 1-5, Tanski Winter 2015 USF Tampa, Team 1-5, Tanski Winter 2015 的会员
USFT-TANSKI-W15S1G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 320
