简介
Steps show you how to remove a battery by cutting the attached wires out of this device.
你所需要的
Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
Carefully pry up the battery by wedging the plastic opening tool under the battery. It is glued to the screen so it will be a delicate removal process.
结论
Tape the battery back onto the back of the device's screen and snap the rear case back on to finish this repair.
