跳转到主内容
Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement
你所需要的
  1. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate your device.
    • Flip device onto its back.
  2. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the tablet's back cover.
  3. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 步骤 3 中的图像 1,1
    • Locate the battery and remove it.
    • If you wish to replace the battery you can do so here.
  4. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Back Panel: 步骤 4 中的图像 1,2 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
  5. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pop out the back cover.
  6. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Start by disconnecting the cables attached to the motherboard
    • use the spudger to lift the connectors vertically off. They should pop off with relative ease
    • The last connector has a yellow tab. Pull up on the tab until the small metal catch lifts up. Then pull straight back to remove the connector from its socket.
  7. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips PH1, remove all 6 of the 3x2.5mm screws (circled in red) holding the motherboard in place.
  8. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 步骤 8 中的图像 1,1
    • Using the spudger lift the motherboard out of the tablet frame.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 487
