跳转到主内容
Qualcomm Snapdragon 800 Mobile Development Antenna Replacement
你所需要的
  1. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Battery: 步骤 1 中的图像 1,2 Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate your device.
    • Flip device onto its back.
  2. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 步骤 2 中的图像 1,1
    • Remove the tablet's back cover.
  3. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 步骤 3 中的图像 1,1
    • Locate the battery and remove it.
    • If you wish to replace the battery you can do so here.
  4. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Back Panel: 步骤 4 中的图像 1,2 Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
  5. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 步骤 5 中的图像 1,1
    • Pop out the back cover.
  6. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Antennas: 步骤 6 中的图像 1,1
    • After removing the panel and the battery, your tablet should look like this.
  7. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 步骤 7 中的图像 1,2 Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 步骤 7 中的图像 2,2
    • Locate the tablet's antennas.
    • Remove the two 3x2.5mm screws holding them down.
  8. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 步骤 8 中的图像 1,1
    • Remove antennas and replace them as needed.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 326
