跳转到主内容
Qualcomm QCP-2760 Keypad Replacement
你所需要的
  1. Qualcomm QCP-2760 Keypad Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Qualcomm QCP-2760 Keypad Replacement, Rear Backing: 步骤 2 中的图像 1,2 Qualcomm QCP-2760 Keypad Replacement, Rear Backing: 步骤 2 中的图像 2,2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
  3. Qualcomm QCP-2760 Keypad Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
  4. Qualcomm QCP-2760 Keypad Replacement: 步骤 4 中的图像 1,2 Qualcomm QCP-2760 Keypad Replacement: 步骤 4 中的图像 2,2
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
  5. Qualcomm QCP-2760 Keypad Replacement: 步骤 5 中的图像 1,2 Qualcomm QCP-2760 Keypad Replacement: 步骤 5 中的图像 2,2
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
  6. Qualcomm QCP-2760 Keypad Replacement, Keypad: 步骤 6 中的图像 1,1
    • Remove keypad circuit board by lifting up circuit board while pulling clip.
    • Remove rubber keypad
    • Insert new rubber keypad.
结论
Colin Packard
于09/30/14注册
101 声望
撰写一个指南
团队
Ohio State, Team 1-4, Buehl Fall 2014 Ohio State, Team 1-4, Buehl Fall 2014 的会员
OSU-BUEHL-F14S1G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 186
