跳转到主内容
Qanba Crystal Joystick and Buttons Replacement
你所需要的
  1. Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: 步骤 1 中的图像 1,3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: 步骤 1 中的图像 2,3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: 步骤 1 中的图像 3,3
    • Use the Phillips #1 screwdriver to remove the eight 20 mm screws.
    • Remove the metal plate to gain access to the internals of the device.
  2. Qanba Crystal Joystick and Buttons Replacement: 步骤 2 中的图像 1,3 Qanba Crystal Joystick and Buttons Replacement: 步骤 2 中的图像 2,3 Qanba Crystal Joystick and Buttons Replacement: 步骤 2 中的图像 3,3
    • Taking a picture or marking cables with masking tape is advised as it will help with the reassembly process.
    • Each button has three cables, unplug these from each one.
    • The joystick has two cables, unplug both of these.
    • The use of ESD safe tweezers may assist with unplugging the cables.
  3. Qanba Crystal Joystick and Buttons Replacement: 步骤 3 中的图像 1,3 Qanba Crystal Joystick and Buttons Replacement: 步骤 3 中的图像 2,3 Qanba Crystal Joystick and Buttons Replacement: 步骤 3 中的图像 3,3
    • Use the Phillips #1 screwdriver to remove the four 10 mm screws.
    • Use a flathead screwdriver to hold the screw in place.
    • Twist off the ball top of the joystick while holding the screw in place with a screwdriver.
    • Remove the joystick and all of it's components.
  4. Qanba Crystal Joystick and Buttons Replacement: 步骤 4 中的图像 1,1
    • Press in the tabs on the top and bottom of the buttons to remove them.
    • The outline of the buttons are sharp, do exercise caution with the removal of the buttons.
  5. Qanba Crystal Joystick and Buttons Replacement: 步骤 5 中的图像 1,3 Qanba Crystal Joystick and Buttons Replacement: 步骤 5 中的图像 2,3 Qanba Crystal Joystick and Buttons Replacement: 步骤 5 中的图像 3,3
    • Flip the controller over.
    • Peel the six shiny stickers and their epoxy glue off of the controller.
    • Remove the six newly revealed Phillips screws.
    • Remove the acrylic panel.
结论
Kevin Vu
于06/29/21注册
121 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 70
总计 1,598
