简介
Attention, tailors! This manual offers a comprehensive guide on replacing a broken needle in your QSEW QS-1201 computerized embroidery machine. While the process is relatively straightforward, the machine may seem a bit intimidating. If you're not familiar with how it works, follow this guide, and you'll be back to embroidering your favorite items in no time. Pull up your socks and give it a try!
Before you begin, power off the machine and unplug the device from the outlet.
你所需要的
Use a 3.0 mm Flathead screwdriver to loosen the screw.
即将完成!
结论
