跳转到主内容
QFX IT-437 Speaker Replacement
你所需要的
  1. QFX IT-437 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Begin the tear down with a Phillips PH00 screwdriver.
    • Remove two 1.2mm x 3mm Phillips screws.
  2. QFX IT-437 Speaker Replacement: 步骤 2 中的图像 1,2 QFX IT-437 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry open the case.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires that connect to the speaker.
  3. QFX IT-437 Speaker Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the tape over the wires connecting the speaker to the motherboard.
  4. QFX IT-437 Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the speaker unit from the tablet and set aside.
结论
Douglas
于01/28/15注册
482 声望
创作了4篇指南
团队
Pasco Hernando, Team 5-2, Prince Winter 2015 Pasco Hernando, Team 5-2, Prince Winter 2015 的会员
PHSC-PRINCE-W15S5G2
6 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 851
