跳转到主内容
QFX IT-437 Motherboard Replacement
你所需要的
  1. QFX IT-437 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Motherboard Replacement: 步骤 2 中的图像 1,2 QFX IT-437 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Motherboard Replacement: 步骤 3 中的图像 1,1
    • In order to unseat the motherboard, use the Phillips PH00 screw driver bit to remove the three 1.2mm x 3mm screws.
  4. QFX IT-437 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Once the motherboard is loose, remove the tape above the SD card slot using an iFixit opening pick.
    • Be careful not to rip or damage the tape or else new tape will have to be used for the new motherboard.
  5. QFX IT-437 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use the spudger to remove the ribbon.
    • Avoid using too much force here or else the ribbon can be ripped.
  6. QFX IT-437 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the spudger in the top corner of the tablet and lift the camera up.
  7. QFX IT-437 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Lift the tape over the wires that are holding them to the tablet insulation.
  8. QFX IT-437 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pull out the motherboard and set it aside.
    • The wires must be soldered back on to the motherboard.
结论
2等其他人完成本指南。
Douglas
于01/28/15注册
482 声望
创作了4篇指南
团队
Pasco Hernando, Team 5-2, Prince Winter 2015 Pasco Hernando, Team 5-2, Prince Winter 2015 的会员
PHSC-PRINCE-W15S5G2
6 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 246
