跳转到主内容
QFX IT-437 Battery Replacement
你所需要的
  1. QFX IT-437 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Battery Replacement: 步骤 2 中的图像 1,2 QFX IT-437 Battery Replacement: 步骤 2 中的图像 2,2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the tape connecting the battery to the motherboard.
    • Save the tape in good condition for the replacement so the wires do not get stuck in the case.
  4. QFX IT-437 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the black tape attaching the wires to the battery.
  5. QFX IT-437 Battery Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
    • The removed wires will have to be soldered back on to the motherboard.
结论
另外一个人完成了本指南。
Douglas
于01/28/15注册
482 声望
创作了4篇指南
团队
Pasco Hernando, Team 5-2, Prince Winter 2015 Pasco Hernando, Team 5-2, Prince Winter 2015 的会员
PHSC-PRINCE-W15S5G2
6 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 399
