跳转到主内容
Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement, Children/Adult Expiratory Filter: 步骤 1 中的图像 1,1
    • Do not begin process while patient is connected. Alarm will sound
    • If necessary, remove the expiratory limb (item 4) of the patient circuit from the exhalation filter.
  2. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: 步骤 2 中的图像 1,1
    • Raise the exhalation filter latch to unlock (item 3).
  3. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: 步骤 3 中的图像 1,1
    • Open the exhalation filter door (item 4).
    • Remove the existing filter. Dispose of properly as per institution’s guidelines on disposing hazardous waste.
  4. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: 步骤 5 中的图像 1,1
    • Ensure filter is properly attached to ventilator
    • Only use filters designed for Puritan Bennett 980 Series Ventilator
    • Insert the new filter by sliding the filter along the tracks in the door. Ensure the from patient port (item 6) aligns with the cutout in the door and points away from the ventilator.
    • Note: The condensate vial (item 5) is removable for discarding accumulated liquid. Turn this vial clockwise to remove. Turn this vial counterclockwise to install.
  5. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: 步骤 6 中的图像 1,1
    • Close the exhalation filter door (item 4).
  6. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: 步骤 7 中的图像 1,1
    • Lower the exhalation filter latch to secure the filter (item 3).
终点
另外一个人完成了本指南。
Silvia Calinov
于04/08/20注册
175 声望
撰写一个指南
团队
Cal Poly, Team S11-G14, Paton Spring 2020 Cal Poly, Team S11-G14, Paton Spring 2020 的会员
CPSU-PATON-S20S11G14
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 37
总计 1,357
