跳转到主内容
Puritan Bennett 840 Oxygen Sensor Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. Puritan Bennett 840 Oxygen Sensor Replacement, Oxygen Sensor: 步骤 1 中的图像 1,1
    • Locate the flexible oxygen sensor access cover on the top edge of the cabinet and firmly push the center of the lower flap of the access cover until the lower flap is dislodged from the cabinet.
  2. Puritan Bennett 840 Oxygen Sensor Replacement: 步骤 2 中的图像 1,1
    • Pinch the bottom and top flaps of the access cover firmly together and pull the access cover away from the cabinet to remove.
  3. Puritan Bennett 840 Oxygen Sensor Replacement: 步骤 3 中的图像 1,1
    • Press the small white release tab away from the sensor cable connector to release the sensor cable connector.
    • While continually pressing the release tab, gently pull the connector from the oxygen sensor.
  4. Puritan Bennett 840 Oxygen Sensor Replacement: 步骤 4 中的图像 1,1
    • Unscrew (counter-clockwise) and remove the oxygen sensor.
  5. Puritan Bennett 840 Oxygen Sensor Replacement: 步骤 5 中的图像 1,1
    • Open the replacement oxygen sensor and O-ring. Make sure the O-ring is at the threaded base of the oxygen sensor, and screw (clockwise) until snug.
结论
To reassemble your device, follow these instructions in reverse order. Calibrate new oxygen sensor by pressing 100% O2/ CAL 2 min key. Run an SST to check the system before using the ventilator on a patient.
2等其他人完成本指南。
团队
Cal Poly, Team S7-G4, Paton Spring 2020 Cal Poly, Team S7-G4, Paton Spring 2020 的会员
CPSU-PATON-S20S7G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 30
总计 1,567
