跳转到主内容
Puritan Bennett 840 BPS Battery Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. Puritan Bennett 840 BPS Battery Replacement, BPS Battery: 步骤 1 中的图像 1,2 Puritan Bennett 840 BPS Battery Replacement, BPS Battery: 步骤 1 中的图像 2,2
    • Before beginning, ensure that the battery is drained and the ventilator is not connected to a power source.
    • Locate the breath delivery unit (BDU) shelf on the ventilator.
    • Locate the battery indicator label on the shelf to determine whether the BPS battery holds a one-hour or four-hour charge - the default for this guide is a four-hour battery.
  2. Puritan Bennett 840 BPS Battery Replacement: 步骤 2 中的图像 1,1
    • Grasp the sides of the front bezel of the BPU and gently spread them away from the ventilator.
    • Pull the bezel outward to remove it from the cart.
    • Use a Phillips screwdriver to remove the two screws that connect the BPS to the BDU shelf at the back of the cart.
  3. Puritan Bennett 840 BPS Battery Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips screwdriver, remove the eleven screws securing the BPS top and front metal covers.
    • If the BPS contains a one-hour battery, only the four screws holding the one-hour battery shield (four on the top cover) need to be removed.
    • Pull the covers away from the BPS.
  4. Puritan Bennett 840 BPS Battery Replacement: 步骤 4 中的图像 1,3 Puritan Bennett 840 BPS Battery Replacement: 步骤 4 中的图像 2,3 Puritan Bennett 840 BPS Battery Replacement: 步骤 4 中的图像 3,3
    • Locate the battery indicator bracket.
    • Cut the zip tie connecting the battery harness (bundle of wires coming from the battery) to the battery indicator bracket.
    • If the ventilator contains a one-hour battery, simply disconnect the battery harness from the battery cable and lift the battery out of the BPS.
  5. Puritan Bennett 840 BPS Battery Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips screwdriver to remove the two screws securing the battery retaining bracket to the rear of the BPS.
  6. Puritan Bennett 840 BPS Battery Replacement: 步骤 6 中的图像 1,1
    • Disconnect the battery connector from J2 on the circuit board next to the battery indicator bracket.
  7. Puritan Bennett 840 BPS Battery Replacement: 步骤 7 中的图像 1,1
    • Using a Phillips screwdriver, loosen the two side screws and the two base screws holding the BPS front bracket.
    • Carefully lift the battery out of the BPS.
结论
2等其他人完成本指南。
Olivia May
于01/23/20注册
606 声望
撰写一个指南
团队
Cal Poly, Team S7-G4, Paton Spring 2020 Cal Poly, Team S7-G4, Paton Spring 2020 的会员
CPSU-PATON-S20S7G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 18
过去 30 天: 36
总计 1,060
