跳转到主内容
Puritan Bennett 540 Battery Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Puritan Bennett 540 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the ventilator on a work table.
  2. Puritan Bennett 540 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the three screws (item one) securing the battery cover with a Torx T10 screwdriver. These screws consist of two Torx head screws on the back panel and one Torx head screw on the bottom of the ventilator, as shown (depends on the version of the device).
  3. Puritan Bennett 540 Battery Replacement: 步骤 3 中的图像 1,1
    • Slide the battery cover ( item 2) off by pulling it towards the back of the ventilator.
  4. Puritan Bennett 540 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the old battery ( item 3) from the battery cover.
  5. Puritan Bennett 540 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the replacement battery from its package and install it into the battery cover. Make sure you remove the pull tabs (if they are present) from the battery’s contacts.
  6. Puritan Bennett 540 Battery Replacement: 步骤 6 中的图像 1,1
    • Place the battery cover containing the replacement battery back onto its slide rails within the ventilator.
    • Note: Push on the battery cover from the rear towards the front when tightening screws to make sure nothing breaks.
结论
To reassemble your device, follow these instructions in reverse order
Nina Aliamus
于04/08/20注册
133 声望
撰写一个指南
团队
Cal Poly, Team S7-G7, Paton Spring 2020 Cal Poly, Team S7-G7, Paton Spring 2020 的会员
CPSU-PATON-S20S7G7
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 139
