跳转到主内容
Puritan Bennett 540 Alarm Resetting Technique
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. Puritan Bennett 540 Alarm Resetting Technique, Puritan Bennett 540 Alarm Resetting Technique: 步骤 1 中的图像 1,1
    • Press the MENU Key to access the Alarm Settings Menu.
  2. Puritan Bennett 540 Alarm Resetting Technique: 步骤 2 中的图像 1,2 Puritan Bennett 540 Alarm Resetting Technique: 步骤 2 中的图像 2,2
    • Press the down arrow key to position the cursor on the “Alarm Logs” line, if this is not already the case.
  3. Puritan Bennett 540 Alarm Resetting Technique: 步骤 3 中的图像 1,1
    • Press the Enter key to confirm the selection of the Alarm Menu.
  4. Puritan Bennett 540 Alarm Resetting Technique: 步骤 4 中的图像 1,2 Puritan Bennett 540 Alarm Resetting Technique: 步骤 4 中的图像 2,2
    • Press the up arrow key to position the cursor on the “Reactivate Paused Alarm” line. The following graphic shows the resulting display.
  5. Puritan Bennett 540 Alarm Resetting Technique: 步骤 5 中的图像 1,3 Puritan Bennett 540 Alarm Resetting Technique: 步骤 5 中的图像 2,3 Puritan Bennett 540 Alarm Resetting Technique: 步骤 5 中的图像 3,3
    • Press the Enter key for at least three (3) seconds. The following events occur:
    • A “beep” sounds.
    • An audible alarm sounds.
    • An alarm indicator illuminates.
    • The messages of all active alarms are displayed in a loop in the Ventilation and Alarm menus.
    • The Audio Paused symbol disappears (if it was displayed).
    • The Alarm Paused symbol disappears.
结论
There is no need to reassemble the device, but if the condition persists you can try resetting the audio again.
kerribyrne
于04/08/20注册
267 声望
创作了2篇指南
团队
Cal Poly, Team S7-G7, Paton Spring 2020 Cal Poly, Team S7-G7, Paton Spring 2020 的会员
CPSU-PATON-S20S7G7
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 113
