跳转到主内容
Puritan Bennett 540 Air Inlet Filter Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Puritan Bennett 540  Air Inlet Filter Replacement, Air Inlet Filter: 步骤 1 中的图像 1,1
    • Hold the filter between your fingers and pinch. Pull the filter outwards (towards you).
  2. Puritan Bennett 540  Air Inlet Filter Replacement: 步骤 2 中的图像 1,1
    • Remove the filter and discard it. Do not save it. When removed, it should look like the attached image.
    • Place the new filter in the device by making sure that:
    • a. The fine particle side of the filter faces outwards, away from the ventilator.
    • b. The filter is properly installed in its housing. Proper installation of the filter prevents particles from entering the device. Remember that the air inlet filter is not reusable; do not wash, clean, or reuse it!
结论
There is no reassembly needed after replacing the inlet filter.
kerribyrne
于04/08/20注册
267 声望
创作了2篇指南
团队
Cal Poly, Team S7-G7, Paton Spring 2020 Cal Poly, Team S7-G7, Paton Spring 2020 的会员
CPSU-PATON-S20S7G7
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 81
