跳转到主内容
Prusa i3 Mk2 Nozzle Replacement
你所需要的
  1. Prusa i3 Mk2  Nozzle Replacement, Nozzle: 步骤 1 中的图像 1,3 Prusa i3 Mk2  Nozzle Replacement, Nozzle: 步骤 1 中的图像 2,3 Prusa i3 Mk2  Nozzle Replacement, Nozzle: 步骤 1 中的图像 3,3
    • Turn the 3D printer on using the power switch.
    • Move the head to the highest position on the Z axis. This provides working room to access the head.
    • Heat the nozzle up. This step depends on what type of filament is currently in the machine (e.g. 190 for PLA, 220 for ABS).
    • Remove filament from the 3D printer.
    • Clean off the old nozzle with tweezers.
  2. Prusa i3 Mk2  Nozzle Replacement: 步骤 2 中的图像 1,3 Prusa i3 Mk2  Nozzle Replacement: 步骤 2 中的图像 2,3 Prusa i3 Mk2  Nozzle Replacement: 步骤 2 中的图像 3,3
    • Remove the 1 X M3 Bolt holding on the fan shroud on the outlet of the fan.
    • Remove the fan shroud.
    • Remove the 2 X M3 Bolts holding on the blower fan.
    • Remove the fan and place it in a safe location.
    • The wires are still attached to the fan, be careful to not break the connectors.
  3. Prusa i3 Mk2  Nozzle Replacement: 步骤 3 中的图像 1,1
    • Remove the 2 X M3 Bolts from the Extruder Plate.
  4. Prusa i3 Mk2  Nozzle Replacement: 步骤 4 中的图像 1,2 Prusa i3 Mk2  Nozzle Replacement: 步骤 4 中的图像 2,2
    • Remove the two M3 Bolts that are holding on the Extruder Cooling Fan.
    • Remove the Extruder Plate carefully, and avoid touching the hot metal print head.
    • Leave one bolt on the back of the fan so that the fan stays attached to the rest of the assembly.
  5. Prusa i3 Mk2  Nozzle Replacement: 步骤 5 中的图像 1,1
    • Make sure the nozzle is heated up before doing this step to prevent damage to the print head.
    • Use an adjustable crescent wrench and a 7mm wrench or socket to remove the old nozzle.
  6. Prusa i3 Mk2  Nozzle Replacement: 步骤 6 中的图像 1,3 Prusa i3 Mk2  Nozzle Replacement: 步骤 6 中的图像 2,3 Prusa i3 Mk2  Nozzle Replacement: 步骤 6 中的图像 3,3
    • Screw in the new nozzle using a socket to get the threads started.
    • Use a crescent wrench and a 7mm wrench or socket to tighten a quarter turn past hand tight.
    • Do not over tighten. Damage to the nozzle or print head could occur.
    • Insert some new filament and push it through to test the connection.
结论
To reassemble your device, follow these instructions in reverse order. Once reassembled, print a test print to ensure the replaced nozzle is not leaking.
6等其他人完成本指南。
Aubrey Woern
于09/24/17注册
253 声望
撰写一个指南
团队
Michigan Tech, Team S5-G5, Galliah Fall 2017 Michigan Tech, Team S5-G5, Galliah Fall 2017 的会员
MTU-GALLIAH-F17S5G5
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 54
总计 10,185
