跳转到主内容
Prusa i3 MK3 Z-Axis Bearings Replacement
你所需要的
  1. Prusa i3 MK3 Z-Axis Bearings Replacement, X-Axis Belt: 步骤 1 中的图像 1,3 Prusa i3 MK3 Z-Axis Bearings Replacement, X-Axis Belt: 步骤 1 中的图像 2,3 Prusa i3 MK3 Z-Axis Bearings Replacement, X-Axis Belt: 步骤 1 中的图像 3,3
    • Orient the printer so that the screen is facing to the left.
    • Using the On/Off button, switch the printer into the Off position.
    • Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
    • Ensure the printer has cooled to room temperature before beginning disassembly.
  2. Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 2 中的图像 1,3 Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 2 中的图像 2,3 Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 2 中的图像 3,3
    • Orient the printer so that the screen is facing away from you.
    • Remove the five 2.5mm X 10mm socket head screws on the back of the extruder assembly.
    • Remove the back cover and pull it away from the extruder assembly. Do not put too much tension on the wires.
  3. Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 3 中的图像 1,3 Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 3 中的图像 2,3 Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 3 中的图像 3,3
    • Orient the printer so that the screen is facing you.
    • Loosen the 2.5mm X 18mm tension set screw.
    • Loosen the two 2.5mm X 18mm socket head screws on the right, holding on to the X-axis motor.
    • Slightly loosen the 2.5mm X 18mm pivot screw on the left. This screw will act as a pivot for the X-axis motor.
    • Pivot the motor to release the tension on the belt.
  4. Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 4 中的图像 1,2 Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 4 中的图像 2,2
    • Loosen the 2.5mm X 18mm and 2.5mm X 30mm socket head screws that hold the belt in. You do not need to remove these screws.
    • Remove the belt from the belt grips by pulling the belt towards you.
    • Un-feed the belt from its track. The belt should now be removed.
  5. Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 5 中的图像 1,1
    • During reassembly, ensure proper tension on the belt before reattaching the back cover of the extruder assembly.
    • With the extruder assembly positioned in the center of the X-axis rails, press the top of the belt with moderate pressure. The top of the belt should not be able to touch the bottom of the belt.
  6. Prusa i3 MK3 Z-Axis Bearings Replacement, X-Axis Carriage: 步骤 6 中的图像 1,2 Prusa i3 MK3 Z-Axis Bearings Replacement, X-Axis Carriage: 步骤 6 中的图像 2,2
    • Remove the two 2.5mm X 10mm socket head screws that secure the Z-axis rod and screw bracket. Do this for both brackets.
  7. Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 7 中的图像 1,2 Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 7 中的图像 2,2
    • Lift the X-axis carriage off of the Z-axis rod and screw.
    • The X-axis motor can be removed and placed to the side for easier disassembly.
    • Be careful not to damage any of the wiring.
  8. Prusa i3 MK3 Z-Axis Bearings Replacement, Z-Axis Bearings: 步骤 8 中的图像 1,2 Prusa i3 MK3 Z-Axis Bearings Replacement, Z-Axis Bearings: 步骤 8 中的图像 2,2
    • Place the X-axis carriage on the build plate so that the front of the extruder assembly is facing you.
    • Remove the two 2.5mm X 18mm socket head screws on both of the Z-axis screw guides. There is one on each side of the carriage assembly.
  9. Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 9 中的图像 1,2 Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 9 中的图像 2,2
    • Orient the X-axis carriage so that the bottom of the screw guide is facing you.
    • Use a blunt ram tool to push the Z-axis bearings out of the housing. Be sure to push the bearings out from the bottom side.
  10. Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 10 中的图像 1,2 Prusa i3 MK3 Z-Axis Bearings Replacement: 步骤 10 中的图像 2,2
    • During reassembly, grease the Z-axis bearings with the PRUSA Lubricant Applicator.
结论
To reassemble your device, follow these instructions in reverse order. Use Step 9 for reference.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 72
