简介
The X-axis carriage in your PRUSA i3 MK3 supports the extruder assembly. The X-axis carriage must be removed to replace the X-axis bearings and the Z-axis bearings. To replace the X-axis carriage, follow the steps in this guide. Ensure that you do not lose any of the parts or socket head screws that are removed during replacement.
你所需要的
Orient the printer so that the screen is facing to the left.
Using the On/Off button, switch the printer into the Off position.
Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
Orient the printer so that the screen is facing you.
Loosen the 2.5mm X 18mm tension set screw.
Loosen the two 2.5mm X 18mm socket head screws on the right, holding on to the X-axis motor.
Slightly loosen the 2.5mm X 18mm pivot screw on the left. This screw will act as a pivot for the X-axis motor.
Pivot the motor to release the tension on the belt.
Orient the printer so that the screen is facing away from you.
Loosen the 2.5mm X 18mm and 2.5mm X 30mm socket head screws that hold the belt in. You do not need to remove these screws.
Remove the belt from the belt grips by pulling the belt towards you.
Un-feed the belt from its track. The belt should now be removed.
Remove the two 2.5mm X 10mm socket head screws that secure the Z-axis rod and screw bracket. Do this for both brackets.
