跳转到主内容
Prusa i3 MK3 Filament Sensor Replacement
你所需要的
  1. Prusa i3 MK3 Filament Sensor Replacement, Filament Sensor: 步骤 1 中的图像 1,3 Prusa i3 MK3 Filament Sensor Replacement, Filament Sensor: 步骤 1 中的图像 2,3 Prusa i3 MK3 Filament Sensor Replacement, Filament Sensor: 步骤 1 中的图像 3,3
    • Orient the printer so that the screen is facing to the left.
    • Using the On/Off button, switch the printer into the Off position.
    • Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
    • Ensure the printer has cooled to room temperature before beginning disassembly.
  2. Prusa i3 MK3 Filament Sensor Replacement: 步骤 2 中的图像 1,3 Prusa i3 MK3 Filament Sensor Replacement: 步骤 2 中的图像 2,3 Prusa i3 MK3 Filament Sensor Replacement: 步骤 2 中的图像 3,3
    • Orient the printer so that the top of the extruder head can be accessed.
    • Remove the two 2.5mm X 10mm socket head screws. These screws secure the cover of the filament sensor.
    • Remove the filament sensor cover.
  3. Prusa i3 MK3 Filament Sensor Replacement: 步骤 3 中的图像 1,2 Prusa i3 MK3 Filament Sensor Replacement: 步骤 3 中的图像 2,2
    • Orient the printer so that the screen is facing to the right.
    • Loosen the two 2.5mm X 40mm socket head screws while holding the extruder head firmly, keeping pressure on the opposite side.
    • Ensure the screws have cleared the embedded square nuts on the back side.
    • Be careful not to lose the small springs that are held in place by the screws.
  4. Prusa i3 MK3 Filament Sensor Replacement: 步骤 4 中的图像 1,2 Prusa i3 MK3 Filament Sensor Replacement: 步骤 4 中的图像 2,2
    • Remove the 3D-printed cover piece on top of the extruder access door. (Your printer might be missing this part.)
  5. Prusa i3 MK3 Filament Sensor Replacement: 步骤 5 中的图像 1,3 Prusa i3 MK3 Filament Sensor Replacement: 步骤 5 中的图像 2,3 Prusa i3 MK3 Filament Sensor Replacement: 步骤 5 中的图像 3,3
    • Orient the printer so that the screen is facing away from you.
    • Remove the 2.5mm X 30mm socket head screw located on the top left of the backside of the extruder head.
    • Rotate the printer so that the screen is facing to the left.
    • Remove the extruder access door from the extruder head.
    • Be careful not to lose the square nuts that hold the screws removed in Step 3. (They sit inside the extruder access door.)
  6. Prusa i3 MK3 Filament Sensor Replacement: 步骤 6 中的图像 1,3 Prusa i3 MK3 Filament Sensor Replacement: 步骤 6 中的图像 2,3 Prusa i3 MK3 Filament Sensor Replacement: 步骤 6 中的图像 3,3
    • Remove the 2.5mm X 10mm socket head screw located behind the extruder access door that was removed in Step 5.
  7. Prusa i3 MK3 Filament Sensor Replacement: 步骤 7 中的图像 1,3 Prusa i3 MK3 Filament Sensor Replacement: 步骤 7 中的图像 2,3 Prusa i3 MK3 Filament Sensor Replacement: 步骤 7 中的图像 3,3
    • Locate the filament sensor.
    • Hold the filament sensor in place while unplugging the wiring connection.
    • Use caution because the wiring connections may be fragile.
    • Remove the filament sensor.
结论
To reassemble your device, follow these instructions in reverse order. During reassembly, ensure not to tighten the socket head screws too tight.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 108
