跳转到主内容
Protocol Vento Wi-Fi Antenna Replacement
你所需要的
  1. Protocol Vento Wi-Fi Antenna Replacement, Battery: 步骤 1 中的图像 1,1
    • Grasp the tail end of the drone where the lip of the battery protrudes.
  2. Protocol Vento Wi-Fi Antenna Replacement: 步骤 2 中的图像 1,1
    • Pull away from the drone to remove the battery.
    • Do not attempt any repairs or replacements before removing the battery from the drone.
  3. Protocol Vento Wi-Fi Antenna Replacement, Transmitter Board: 步骤 3 中的图像 1,1
    • To get into the drone, twelve total screws need to be removed:
    • Ten 5.7mm Phillips #000 screws from the bottom of the drone body.
    • Two 4.5mm Phillips #000 screws at the front of the drone.
    • It is not necessary to remove the four screws on the arms of the drone.
  4. Protocol Vento Wi-Fi Antenna Replacement: 步骤 4 中的图像 1,3 Protocol Vento Wi-Fi Antenna Replacement: 步骤 4 中的图像 2,3 Protocol Vento Wi-Fi Antenna Replacement: 步骤 4 中的图像 3,3
    • Flip the drone over and lift off the top plastic shell of the drone.
  5. Protocol Vento Wi-Fi Antenna Replacement: 步骤 5 中的图像 1,2 Protocol Vento Wi-Fi Antenna Replacement: 步骤 5 中的图像 2,2
    • Remove the foam adhesive pad located on the Wi-Fi transmitter board.
  6. Protocol Vento Wi-Fi Antenna Replacement: 步骤 6 中的图像 1,2 Protocol Vento Wi-Fi Antenna Replacement: 步骤 6 中的图像 2,2
    • Pry the gold Wi-Fi antenna connector, located under the previously removed foam pad, away from the Wi-Fi transmitter board to disconnect it.
    • Be sure to only apply force to the gold connector and not the black wire attached to it, as the connection between the two is very fragile.
  7. Protocol Vento Wi-Fi Antenna Replacement: 步骤 7 中的图像 1,1
    • Remove the two 3.8mm Phillips #000 screws from the Wi-Fi transmitter board.
    • Be careful with the delicate ribbon cable attached to the camera.
  8. Protocol Vento Wi-Fi Antenna Replacement: 步骤 8 中的图像 1,1
    • Disconnect the white clip that connects the four colored wires (black, orange, red, blue) to the motherboard.
    • Be sure to pull only on the white clip, as to avoid damaging the wires.
  9. Protocol Vento Wi-Fi Antenna Replacement: 步骤 9 中的图像 1,2 Protocol Vento Wi-Fi Antenna Replacement: 步骤 9 中的图像 2,2
    • Gently pull the black wedge away from the main board until it shifts to a stop. You will feel it slide out, then stop.
    • The black insert acts as a wedge to keep the ribbon cable attached to the board. The wedge needs to be jostled loose before the cable can be removed.
    • Lightly pull the ribbon cable away from the connector.
  10. Protocol Vento Wi-Fi Antenna Replacement, Front Camera: 步骤 10 中的图像 1,1
    • Remove the two 4.9mm Phillips #000 screws securing the camera to the front of the drone body.
  11. Protocol Vento Wi-Fi Antenna Replacement: 步骤 11 中的图像 1,3 Protocol Vento Wi-Fi Antenna Replacement: 步骤 11 中的图像 2,3 Protocol Vento Wi-Fi Antenna Replacement: 步骤 11 中的图像 3,3
    • Lift the camera holder and the camera up and away from the drone.
  12. Protocol Vento Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 12 中的图像 1,1
    • Unscrew the four 4.9mm Phillips #000 corner screws that are securing the motherboard’s black base to the drone.
    • It is not necessary to unscrew the motherboard from the black base.
  13. Protocol Vento Wi-Fi Antenna Replacement: 步骤 13 中的图像 1,2 Protocol Vento Wi-Fi Antenna Replacement: 步骤 13 中的图像 2,2
    • Grasp and pull each of the four drone arms in the direction of their propellers, one at a time, to remove them from the drone.
  14. Protocol Vento Wi-Fi Antenna Replacement: 步骤 14 中的图像 1,1
    • Gently pull the motherboard out of the drone.
    • The four arms of the drone will dangle from the motherboard by their cords.
  15. Protocol Vento Wi-Fi Antenna Replacement: 步骤 15 中的图像 1,1
    • Pull the black, rectangular shell out of the drone.
    • It is not attached with screws.
  16. Protocol Vento Wi-Fi Antenna Replacement: 步骤 16 中的图像 1,2 Protocol Vento Wi-Fi Antenna Replacement: 步骤 16 中的图像 2,2
    • Hold the drone’s shell with both hands so that the inside of the shell is facing you.
    • Gently flex the shell outward, so that the two latches (holding the antenna in place) move apart slightly.
    • At the same time, push the antenna from the back of the drone towards you until it releases from the latches.
结论
3等其他人完成本指南。
Maria Larcomb
于02/15/18注册
926 声望
创作了5篇指南
团队
USF Tampa, Team S1-G2, Leahy Spring 2018 USF Tampa, Team S1-G2, Leahy Spring 2018 的会员
USFT-LEAHY-S18S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 7
总计 292
