跳转到主内容
Protocol Vento Motor Replacement
你所需要的
  1. Protocol Vento Motor Replacement, Battery: 步骤 1 中的图像 1,1
    • Grasp the tail end of the drone where the lip of the battery protrudes.
  2. Protocol Vento Motor Replacement: 步骤 2 中的图像 1,1
    • Pull away from the drone to remove the battery.
    • Do not attempt any repairs or replacements before removing the battery from the drone.
  3. Protocol Vento Motor Replacement, Propeller: 步骤 3 中的图像 1,1
    • Place a prying tool under the base of the propeller.
  4. Protocol Vento Motor Replacement: 步骤 4 中的图像 1,2 Protocol Vento Motor Replacement: 步骤 4 中的图像 2,2
    • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
  5. Protocol Vento Motor Replacement, Motor: 步骤 5 中的图像 1,1
    • Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
  6. Protocol Vento Motor Replacement: 步骤 6 中的图像 1,2 Protocol Vento Motor Replacement: 步骤 6 中的图像 2,2
    • Hold the base of the arm while gently pulling the motor cover away from the arm.
    • Do not pull too hard because there are wires attaching the motor to the drone. Do not sever the wires.
  7. Protocol Vento Motor Replacement: 步骤 7 中的图像 1,2 Protocol Vento Motor Replacement: 步骤 7 中的图像 2,2
    • Gently pull the motor out from the plastic cover.
    • Do not squeeze or pull too hard, as to not damage the motor connection.
  8. Protocol Vento Motor Replacement: 步骤 8 中的图像 1,2 Protocol Vento Motor Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • The motor’s blue and red wires are secured via a white clip. This clip is inserted into a slot in the drone’s leg.
    • Grasp the clip’s edges with a pair of tweezers and pull outward.
    • Do not pull directly on the wires, as to not separate the wires from the clip.
结论
4等其他人完成本指南。
Maria Larcomb
于02/15/18注册
926 声望
创作了5篇指南
团队
USF Tampa, Team S1-G2, Leahy Spring 2018 USF Tampa, Team S1-G2, Leahy Spring 2018 的会员
USFT-LEAHY-S18S1G2
4 名成员
创作了6篇指南
2指南评论
Please send me motor description
suresh virji - 回复
send me protocol vento motor
suresh virji - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 760
